Skip Navigation Links
Exit Print View
Oracle SuperCluster M6-32 HTML Owner’s Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Documentation Library
Feedback
Overview
Determining SuperCluster M6-32 Configurations
Configuration Flowchart
Determine the Number of Compute Servers
Determine the Number of DCUs in Each Compute Server
Determine the Number of CMUs in Each DCU
CMU Overview
Determine the Amount of Memory in Each DCU
Determine the PDomain Configuration on Each Compute Server
Determine the LDom Configuration for Each PDomain
Determining the Best Configuration for Your Situation
Understanding PDomain Configurations
Understanding High Redundancy
Allocating CPU Resources for LDoms
Allocating Memory Resources for LDoms
Understanding PCIe Cards and Slots for LDoms
Understanding Storage for LDoms
Understanding the Hardware
Understanding SuperCluster M6-32
Identifying SuperCluster M6-32 Components
Understanding DCUs
DCU Overview
Understanding DCU Configurations
Understanding Half-Populated DCU Root Complexes
Understanding Fully-Populated DCU Root Complexes
Understanding PDomains
PDomains Overview
PDomain Guidelines
Extended Configuration PDomain Overview
Understanding Extended Configuration PDomains
Base Configuration Overview
Understanding Base Configuration PDomains
Understanding LDoms
Understanding Compute Server Hardware and Networks
CPU and Memory Resources Overview
LDoms and the PCIe Slots Overview
Management Network Overview
10GbE Client Access Network Overview
Understanding the IB Network
IB Network Overview
IB Network Data Paths for a Database Domain
IB Network Data Paths for an Application Domain
Understanding Domains
Dedicated Domains
Understanding SR-IOV Domain Types
Root Domains
I/O Domains
Understanding LDom Configurations for Extended Configuration PDomains
Understanding LDom Configurations for Fully-Populated DCUs (Extended Configuration PDomains)
E4-1 LDom Configuration
E4-2 LDom Configuration
E4-3 LDom Configuration
E4-4 LDom Configuration
Understanding LDom Configurations for Half-Populated DCUs (Extended Configuration PDomains)
E2-1 LDom Configuration
E2-2 LDom Configuration
E2-3 LDom Configuration
E2-4 LDom Configuration
Understanding LDom Configurations for Base Configuration PDomains
Understanding LDom Configurations for Fully-Populated DCUs (Base Configuration PDomains)
B4-1 LDom Configuration
B4-2 LDom Configuration
B4-3 LDom Configuration
B4-4 LDom Configuration
Understanding LDom Configurations for Half-Populated DCUs (Base Configuration PDomains)
B2-1 LDom Configuration
B2-2 LDom Configuration
B2-3 LDom Configuration
B2-4 LDom Configuration
Understanding Clustering Software
Cluster Software Overview
Cluster Software for the Database Domain
Cluster Software for the Oracle Solaris Application Domains
Understanding System Administration Resources
Oracle ILOM Overview
Understanding Platform-Specific Oracle ILOM Features
Oracle Solaris OS Overview
OpenBoot Overview
Oracle ILOM Remote Console Plus Overview
Oracle Hardware Management Pack Overview
Time Synchronization and NTP Service
SNMP Service
Multidomain Extensions to Oracle ILOM MIBs
LDAP/SSL
Active Directory
Hardware Installation
Installing SuperCluster M6-32
Hardware Installation Overview
Weight Specifications
Hardware Installation Task Overview
Hardware Installation Documents
Preparing the Site (Storage Rack and Expansion Racks)
Prepare the Site for the Racks
Storage Rack Components
Physical Specifications
Reviewing Power Requirements
Preparing for Cooling
Preparing the Network
Network Topology
Network Infrastructure Requirements
Compute Server Default Host Names and IP Addresses
Install Cable Drops
Prepare DNS
Cabling SuperCluster M6-32
Compute Server Network Components
Storage Rack Network Components
Cable the ZFS Storage Appliance
ZFS Appliance Power Cord Connection Reference
ZFS Storage Appliance Cabling Reference
Cable IB Switches
Leaf Switch 1 Cabling Reference
Leaf Switch 2 Cabling Reference
IB Switch-to-Switch Cabling Reference
Cable the Ethernet Management Switch
Ethernet Management Switch Cabling Reference
Connect SuperCluster M6-32 to the Facility Networks
Connecting Expansion Racks
Expansion Rack Overview
Expansion Rack Components
Expansion Rack Layouts
Installing Expansion Racks
One Expansion Rack Cabling
Two Expansion Racks Cabling
Three Expansion Racks Cabling
Four Expansion Racks Cabling
Five Expansion Racks Cabling
Six Expansion Racks Cabling
Seven Expansion Racks Cabling
Expansion Rack Default IP Addresses
Understanding Internal Cabling (Expansion Rack)
Administration
Understanding SuperCluster Software
Identify the Version of SuperCluster Software
SuperCluster Tools
Controlling SuperCluster M6-32
Cautions
Power On SuperCluster M6-32
Powering Off SuperCluster M6-32 Gracefully
Power Off SuperCluster M6-32 in an Emergency
Monitoring SuperCluster M6-32 (OCM)
OCM Overview
Access OCM Documentation
Monitoring the System With ASR
ASR Overview
ASR Resources
ASR Installation Overview
Configure ASR on the Compute Servers (Oracle ILOM)
Configure SNMP Trap Destinations for Storage Servers
Configure ASR on the ZFS Storage Appliance
Configuring ASR on the Compute Servers (Oracle Solaris 11)
Approve and Verify ASR Asset Activation
Tuning SuperCluster M6-32
ssctuner Overview
Monitor ssctuner Activity
View Log Files
Change ssctuner Properties and Disable Features
Install ssctuner
Enable ssctuner
Configuring CPU and Memory Resources (osc-setcoremem)
osc-setcoremem Overview
Minimum and Maximum Resources (Dedicated Domains)
Supported Domain Configurations
Plan CPU and Memory Allocations
Display the Current Domain Configuration (osc-setcoremem)
Display the Current Domain Configuration (ldm)
Change CPU/Memory Allocations (Socket Granularity)
Change CPU/Memory Allocations (Core Granularity)
Park Cores and Memory
Access osc-setcoremem Log Files
View the SP Configuration
Revert to a Previous CPU/Memory Configuration
Remove a CPU/Memory Configuration
Obtaining the EM Exadata Plug-in
Confirm System Requirements
Known Issues With the EM Exadata Plug-in
Configuring the Exalogic Software
Exalogic Software Overview
Prepare to Configure the Exalogic Software
Enable Domain-Level Enhancements
Enable Cluster-Level Session Replication Enhancements
Configuring Grid Link Data Source for Dept1_Cluster1
Configuring SDP-Enabled JDBC Drivers for Dept1_Cluster1
Create an SDP Listener on the IB Network
Administering Oracle Solaris 11 Boot Environments
Advantages to Maintaining Multiple Boot Environments
Create a Boot Environment
Mount to a Different Build Environment
Reboot to the Original Boot Environment
Create a Snapshot of a Boot Environment
Remove Unwanted Boot Environments
Administering DISM
DISM Restrictions
Disable DISM
Administering Storage Servers
Monitor Write-through Caching Mode
Shut Down or Reboot a Storage Server
Drop a Storage Server
Glossary
Index
The following tables provide information on the E2-3 PDomain configuration for the half-populated DCU configuration.
Table 13 EMSs, PCIe Slots and Cards, and CPU/Memory Resources (E2-3 Configuration)
Item
LDom 1
LDom 2
LDom 3
EMSs
  • EMS 1 through EMS 4 in first DCU
  • EMS 1 and 2 in second DCU
EMS 4 in second DCU
EMS 3 in second DCU
Hard Drives
  • HDD0 and HDD1 in first DCU as boot and /u01 primary and mirrored drives
  • HDD2 through HDD7 in first DDCU and HDD0 through HDD3 in second DCU available for additional storage
  • HDD4 and HDD5 in second DCU as boot and /u01 primary and mirrored drives
  • No drives available for additional storage
  • HDD6 and HDD7 in second DCU as boot and /u01 primary and mirrored drives
IB HCAs
  • PCIe slots 2, 6, 10, and 14 in first DCU
  • PCIe slots 2 and 6 in second DCU
PCIe slot 14 in second DCU
PCIe slot 10 in second DCU
Empty (free) PCIe slots
  • PCIe slots 1, 4, 5, 7, 8, 9, 11, 12, 13, 15, and 16 in first DCU
  • PCIe slots 1, 4, 5, 7, and 8 in second DCU
13, 15 and 16 in second DCU
9, 11 and 12 in second DCU
Default CPU/Memory Resources
  • 100% of resources in first DCU
  • 50% of resources in second DCU
25% of resources in second DCU
Table 14 Networks (E2-3 Configuration)
LDom 1
LDom 2
LDom 3
Management Network
Active
NET0, using P0 in 1GbE NIC in first DCU
NET0, using VNET through P0 in 1GbE NIC in second DCU
NET0, using VNET through P2 in 1GbE NIC in second DCU
Standby
NET3, using P3 in 1GbE NIC in first DCU
NET1, using VNET through P1 in 1GbE NIC in second DCU
NET1, using VNET through P3 in 1GbE NIC in second DCU
Active
EMS 1, P0 in first DCU
EMS 4, P0 in second DCU
EMS 3, P0 in second DCU
Standby
EMS 2, P1 in second DCU
EMS 4, P1 in second DCU
EMS 3, P1 in second DCU
IB Network: Storage Private Network (DB or App Domains)
Active
P1 in IB HCA in slot 2 in first DCU
P1 in IB HCA in slot 14 in second DCU
P1 in IB HCA in slot 10 in second DCU
Standby
P0 in IB HCA in slot 6 in second DCU
P0 in IB HCA in slot 14 in second DCU
P0 in IB HCA in slot 10 in second DCU
IB Network: Exadata Private Network (DB Domains)
Active
  • P0 in IB HCAs in slots 2, 6, 10, and 14 in first DCU
  • P0 in IB HCAs in slots 2 and 6 in second DCU
Standby
  • P1 in IB HCAs in slots 2, 6, 10, and 14 in first DCU
  • P1 in IB HCAs in slots 2 and 6 in second DCU
IB Network: Oracle Solaris Cluster Private Network (App Domains)
Active
P0 in IB HCA in slot 2 in first DCU
Standby
P1 in IB HCA in slot 6 second DCU
Related Information
