Configuration - Parameters (cf_parameter with GENREPPAR.FMX)
Note: When printing this Report help topic, we recommend printing with Landscape page orientation.
The Configuration report Parameters will display all parameters and the value that has been set for your property.
Application Parameters are configured in Configuration> Application Parameters.
Preview. Select to preview the report in a PDF format.
Print. select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
