Configuration - Application User Setup (cf_users with CFG4.FMX)
Note: When printing this Report help topic, we recommend printing with Landscape page orientation.
The Configuration Report for Application User Setup will display all users that have been configured in the application for the current property, users at properties to which the current logged in user has property access, and users who have access to the logged in property.
The User Setup can be found under the menu Setup>User Configuration.
User. Multi-select LOV for filtering on specific users for the current resort, users at properties to which the current logged in user has property access, and users who have access to the logged in property.
Active. Select this check box to display active users in the report. This is the default. When the check box is unselected, active users will not be displayed in the User LOV.
Inactive. Select this check box to display inactive users in the report. When the check box is unselected, inactive users will not be displayed in the User LOV.
LDAP. Select this check box to include users configured for LDAP access to Opera. This option is selected by default. See LDAP Integration for details.
Preview. Select to preview the report in a PDF format.
Print. Select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
