Promotion Code Statistics (promocd_stats with PROMOCD_STATS.FMX)
Note: When printing this Report help topic, we recommend printing with Landscape page orientation.
This report displays reservations at properties having promotion codes associated with them. Users may select the property, promotion code, and dates of the reservations to compare previous and current promotion code activity. The report is organized by prior and current reservations, room nights, revenue, and the average daily rate.
Property. Select the property, or properties, whose promotion code activity you want to view.
Promotion Code. Select the promotion code(s) whose activity you want to view.
Current From/To Date. Select the current date range for the promotion code activity: From and To Dates.
Prior From/To Date. Select the previous date range for which you would like to compare: From and To Dates.
Preview. Select to preview the report in a PDF format.
Print. Select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
