RMS Rate Code (yield_rate_code with GEN1.FMX)
Note: When printing this Report help topic, we recommend printing with Portrait page orientation.
The RMS Rate Code Report can be used to determine the Rate Strategies that have been set for indicated rate codes. This report is parameter driven by Rate Code or Dates Range. By default, you can view one month of data. In addition, you can view data for the entire period (50 weeks). The rate codes to be printed are determined by a multi select pick box allowing any number of rates to be included.
Note: The data included in this report applies to rate strategies that are configured using the If Times Sold Reaches Condition. See Configuration>Rate Management>Rate Strategy Setup for details.)
From Date. Type or select the calendar button for the beginning date for the report results.
To Date. Type or select the calendar button for the ending date for the report results.
Rate Code. Select the down arrow to choose the rate code(s) to be covered by the report. The default is all rate codes.
Preview. Select to preview the report in a PDF format.
Print. Select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
