-> start /HOST/console [option]
where option can be:
Enables a user with a console (c) role to take control of the console from any current user and force that user into view mode. If you use this option, other users receive warnings that their connections have been forced into read-only mode. When a user ends a console session that used the force option, read-write status is restored to the next user in line, with the most recent user’s read-write status being restored first.
Bypasses the confirmation prompt to start the console.
After the host console has started you see system console output if Oracle Solaris is running. The OpenBoot ok prompt displays if Oracle Solaris is not running.
