Display the System Firmware Versions
The /HOST property displays information about the firmware versions on the host. The output includes the overall system firmware version and the versions of firmware components, such as Oracle ILOM, OpenBoot, and POST.
Note -
You also can determine the versions of firmware in the server and of specific components, such as a drive controller, with the
fwupdate command. The
fwupdate command is provided in the Oracle Hardware Management Pack, which is included in Oracle Solaris 11.3. For information about using
fwpudate, refer to the
Oracle Server CLI Tools for Oracle Solaris 11.3 User's Guide.
- Display
the current host property values.
-> show /HOST
Refer to the Oracle ILOM Administrator's
Guide for Configuration and Maintenance for more information
about the show /HOST command.
- Examine the output to find the
version listed for the system firmware or firmware component you
wanted.
