Before you begin, review the installation prerequisites in Before You Begin.
For instructions, see Preparing the Boot Media.
The Oracle ILOM Summary Information page appears.
The Oracle System Assistant System Overview screen appears.
The Oracle ILOM Remote System Console Plus window appears.
For example, to reset the server, do one of the following:
From the local server, press the Power button on the front panel of the server (for approximately 1 second) to power off the server, and then press the Power button again to power on the server.
From the Oracle ILOM web interface, select Host Management → Power Control, and then select Reset from the Select Action list box.
From the Oracle ILOM command-line interface, type reset /System.
The server begins the boot process, and the BIOS screen appears in the Oracle ILOM Remote System Console Plus window.
This action ensures that the server has the latest software release package installed before you begin the operating system installation.
This action ensures that the server has the latest firmware and BIOS before you begin the operating system installation.
The Install Operating System screen appears.
This is the location of the installation DVD or the ISO installation image.
The Installation Details dialog box appears.
To change boot devices, click No, and select another device.
The server boots.
