The server supports the following Oracle VM Server software.
If you requested that the Oracle VM Server software be preinstalled on the server when you placed your order, Oracle VM Server 3.3 was preinstalled at the factory. If the Oracle VM software is preinstalled on your server, but you do not want to use it, you can install any other supported operating system or virtual machine software on your server.
The Oracle VM Server Hardware Compatibility List (HCL) identifies hardware that is compatible with Oracle VM Server. To find the latest Oracle VM Server version supported for the Oracle Server X5-8, go to the following site and search using your server model number:
http://linux.oracle.com/pls/apex/f?p=117:1:3991604960223967
