Supplemental Software Component Options
Oracle System Assistant provides an application, called InstallPack
to install platform Supplemental Software components. InstallPack has
two options to install Supplemental software: Oracle System Assistant makes
several Supplemental Software components available for the server.
You have two options for installation:
The following table identifies the optional Supplemental Software components that
Oracle System Assistant makes available for your server.
Table 2 Optional Supplemental Software
Qlogic Drivers
Installs Qlogic drivers (FC, FCoE, NIC, iSCSI) using a
wizard.
Typical
Oracle Hardware Management Pack
provides tools to help you manage and configure your
server. It enables you to:
Use a management agent at the operating system level to
enable in-band monitoring of your server hardware over
Simple Network Management Protocol (SNMP). You can use this
information to integrate your server into your data center
management infrastructure.
Use a management agent to enable in-band monitoring of
your server's storage devices, including RAID arrays. You
can view this information from the Oracle Integrated Lights
Out Manager (ILOM) web interface or command-line interface
(CLI).
Use a BIOS configuration tool, which runs on the host
operating system and configures the host BIOS CMOS settings,
host boot order, and some service processor (SP)
settings.
Use IPMItool to access the server's service processor via
the IPMI protocol and perform management tasks.
Custom
Intel Network Connections PROSet for
Windows
Enables additional network features, including NIC Teaming.
Typical
LSI MegaRAID StorCLI
Enables you to configure, monitor, and maintain
RAID on the SAS 3 internal RAID host bus adapter (HBA).
Typical
LSI MegaRAID Storage Manager for
Windows
Typical
Intel Chipset Software Installation
Utility
Automatically tells you if you need to update your chipset INF
files and prompts you to install the files.
Typical
