Go to main content
Oracle® Server X5-4 Installation Guide for Windows Operating Systems
Exit Print View
Updated: December 2015
Set Up the Local Console
  1. To connect a local console, do one of the following:
    • Connect a terminal to the serial management port (SER MGT) either directly or through a terminal emulator.
      Note -  The default speed of the serial management port is 9600 baud.
    • Connect a VGA monitor, keyboard, and mouse to the video port (VGA) and the USB ports.
  2. For serial management port (SER MGT) connections only, to establish a connection to the host serial port:
    1. Type your Oracle ILOM user name and password.
      The default Oracle ILOM user name is root and the password is changeme.
    2. At the Oracle ILOM login prompt, type:
      -> start /HOST/console
    The serial management port output is automatically routed to the server's host serial local console.
Related Information
