This section describes how to register and configure HA for Apache.
You can configure Apache as a failover service or as a scalable service, as follows.
When you configure Apache as a failover service, you place the Apache application resources and the network resources in a single resource group.
When you configure Apache as a scalable service, you create a scalable resource group for the Apache application resources and a failover resource group for the network resources.
The scalable resource group depends on the failover resource group. Additional steps are required to configure Apache as a scalable service. The leading text “For scalable services only” in the following procedure identifies these steps. If you are not configuring Apache as a scalable service, skip the steps marked “For scalable services only.”
This section contains the following information:
