Debug files are automatically generated when certain osc-config-backup steps run.
The osc-config-backup-debug.log file is located in the domain where osc-config-backup is executed.
Functions or commands with a non-null return code are also reported.
The snapshot debug files are related toStep 5 – Backup Domain and Zone ZFS Pools Backup Domain & Zone datasets and are located in each domain.
For example:
# ls -1 /var/log/osc-config-backup-data/*debug*.log* /var/log/osc-config-backup-data/osc-config-backup-debug.log /var/log/osc-config-backup-data/osc-config-backup-debug.log.0 /var/log/osc-config-backup-data/osc-config-backup-debug.log.1 /var/log/osc-config-backup-data/osc-config-backup-debug.log.10 /var/log/osc-config-backup-data/osc-config-backup-debug.log.11 /var/log/osc-config-backup-data/osc-config-backup-debug.log.12 /var/log/osc-config-backup-data/osc-config-backup-debug.log.13 /var/log/osc-config-backup-data/osc-config-backup-debug.log.14 /var/log/osc-config-backup-data/osc-config-backup-debug.log.15 /var/log/osc-config-backup-data/osc-config-backup-debug.log.16 /var/log/osc-config-backup-data/osc-config-backup-debug.log.17 /var/log/osc-config-backup-data/osc-config-backup-debug.log.2 /var/log/osc-config-backup-data/osc-config-backup-debug.log.3 /var/log/osc-config-backup-data/osc-config-backup-debug.log.4 /var/log/osc-config-backup-data/osc-config-backup-debug.log.5 /var/log/osc-config-backup-data/osc-config-backup-debug.log.6 /var/log/osc-config-backup-data/osc-config-backup-debug.log.7 /var/log/osc-config-backup-data/osc-config-backup-debug.log.8 /var/log/osc-config-backup-data/osc-config-backup-debug.log.9 /var/log/osc-config-backup-data/osc-config-backup-snapshotGZ-debug.log /var/log/osc-config-backup-data/osc-config-backup-snapshotNGZ-debug.log #
For example:
# grep 'DBG INFO' /var/log/osc-config-backup-data/osc-config-backup-debug.log setup_iscsi_initiators.sh:227 ** DBG INFO netMask=‘cidr2nmask $CIDR‘ returned 1 **
