Configuring Siebel Open UI > Reference Information for Siebel Open UI > Life Cycle Flows of User Interface Elements > Life Cycle Flows That Create New Records in List AppletsThis topic describes the life cycle flows that Siebel Open UI uses to create a new record in a list applet. Flow That Creates New Records in List Applets, Calling the Siebel ServerFigure 49 illustrates the life cycle flow that Siebel Open UI uses during the call that it makes to the Siebel Server when it creates a new record in a list applet. Siebel Open UI typically calls the following methods during this flow: NewRecord, DeleteRecord, EditField, WriteRecord, and so on. For more information, see DeleteRecord Method, WriteRecord Method, and NewRecord Method.Flow That Creates New Records in List Applets, Processing the Server ReplyFigure 50 illustrates the life cycle flow that Siebel Open UI uses when it processes the reply that it gets from the Siebel Server when it creates a new record in a list applet. This figure illustrates the flow that occurs after Siebel Open UI receives the reply. Flow That Creates New Records in List Applets, Updating the User InterfaceFigure 51 illustrates the life cycle flow that Siebel Open UI uses to update the user interface. The numbers in the diagram indicate the sequence that Siebel Open UI uses during this flow. Flow That Creates New Records in List Applets, Updating the Proxy and Presentation ModelFigure 52 illustrates the life cycle flow that Siebel Open UI uses to update the proxy and presentation model. |
| Configuring Siebel Open UI | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
