Configuring Siebel Open UI > Reference Information for Siebel Open UI > Life Cycle Flows of User Interface Elements > Life Cycle Flows That Handle User Actions in List AppletsThis topic describes the life cycle flows that Siebel Open UI uses depending on an action that the user does in a list applet. Flow That Handles Navigation to Another Row in List AppletsFigure 53 illustrates the flow that Siebel Open UI uses if the user navigates to another row in a list applet. Flow That Handles the Pagination Button in List AppletsFigure 54 illustrates the flow that Siebel Open UI uses if the user clicks the pagination button in a list applet. Flow That Handles a Column Sort in List AppletsFigure 55 illustrates the flow that Siebel Open UI uses if the user sorts a column in a list applet. Flow That Handles a Cell Click in List AppletsFigure 56 illustrates the flow that Siebel Open UI uses if the user clicks a cell in a list applet. Flow That Handles a Cell Edit and Blur in List AppletsFigure 57 illustrates the flow that Siebel Open UI uses if the user edits a cell in a list applet, and then navigates away from this cell. Flow That Handles a Drilldown in List AppletsFigure 58 illustrates the flow that Siebel Open UI uses if the user clicks a drilldown field in a list applet. |
| Configuring Siebel Open UI | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
