| Siebel Product Administration Guide > Product and Promotion Eligibility and Compatibility > Eligibility and Compatibility Workflow Reference > Check Eligibility & Compatibility - Default Workflow
 This workflow is responsible for checking the eligibility and compatibility of a quote or order line item. This workflow is shown in Figure 19.
Figure 19.	Check Eligibility & Compatibility - Default Workflow
 Workflow Description. This workflow does the following:
Project Asset Key?. Determines whether the Projected Asset Key is present.
Query Projected Asset. If the Projected Asset Key is present, searches for the asset.
Name Change. Calls the Conditional Action Transform for the Business Service Row Set Transformation Toolkit.
Product E & C. Calls the Product Eligibility & Compatibility - Default workflow.
Store Instance Information. Stores instance information that will be used in the Delete RowSet Data step.
Multiple Popup Workflow. Calls the Compatibility Multiple Popup Workflow.
Delete RowSet?. Determines whether any Line Items in the Row Set have been marked for deletion.
Delete RowSet Data. Deletes any Line Items that are marked for deletion.
