| Siebel Product Administration Guide > Product and Promotion Eligibility and Compatibility > Eligibility and Compatibility Workflow Reference > Pricing and Eligibility Procedure - Default Workflow
 Pricing and Eligibility Procedure - Default workflow will check the Eligibility and Compatibility of a Line Item and then do Pricing. This workflow is shown in Figure 20.
Figure 20.	Pricing and Eligibility Procedure - Default Workflow
 Workflow Description. This workflow does the following:
Product E + C. Calls the Check Eligibility & Compatibility - Default workflow, which checks eligibility and compatibility for the Line Items.
Pricing. Calls the Pricing Procedure - Default workflow, which prices the line items.
