Table 15.	Open UI Web Templates for Siebel Product Configurator
    | ecfgproducttabs_v14.swt  | Tab Product Theme OUI | The product tab theme displays the product configuration UI with tabs and with Previous and Next buttons to navigate between groups. |
    | ecfggroupstandard_v14.swt | Standard Group Theme OUI | The group theme displays a div section (which is like a table row) for each relationship that is part of the group definition. |
    | ecfgcontrolcomboprice_v14.swt | Combo Box with Price OUI | The control combo price theme displays the products that are part of the relationship as option items in a combo box. |
    | sisomecfgbaseautorepricetwocol_v14.swt | SIS OM base Theme With Auto Pricing OUI | The base theme displays two parts in the configuration page. The right hand section displays the product details, pricing and any messages associated with the product configuration, and the left hand section displays the product configuration UI.  |
    | ecfgcontrolradioprice_v14.swt | Radio Buttons with Price OUI | The control radio price theme displays the products that are part of the relationship as option buttons. |
    | ecfgcontrolcheckprice_v14.swt  | Check Box with Price OUI | The control check price displays the products that are part of the relationship as check box options. |
    | ecfgobjmessages_v14.swt | n/a | Called as include SWT. This template controls the product related information that is displayed on the right hand section. |
    | ecfgportheader_v14.swt | n/a | Called as include SWT. This template controls the header for the div section displayed for the relationship. |
    | ecfgportfooter_v14.swt | n/a | Called as include SWT. This template controls the footer for the div section displayed for the relationship. |
    | ecfgtoplevelbuttons_v14.swt | n/a | Called as include SWT. This template displays various action buttons that control the product configuration. |
    | ecfgobjglobalsignals_v14.swt | n/a | Called as include SWT. This template displays the various messages that are generated during the configuration process.  |
