Siebel Product Administration Guide > Siebel Configurator Web Templates > About Customizing Configurator Templates for Open UIThe themes and controls that are available for Open UI are the same as those used with the High Interactivity UI. The themes use different SWT files. The Open UI versions are in webtempl\ouiwebtempl. The Open UI framework for Configurator uses a different architecture from the High Interactivity UI framework, as you can see in Figure 13. The Siebel Web Templates used to implement these controls for Open UI are different than those used for the High Interactivity UI. If you customize the Siebel Web Templates, you must do it differently for Open UI. The main difference of the Siebel Web Templates for Open UI are:
In the Object Manager (written in C++), the main differences are:
In the client (browser), the main differences are:
Customizations of Web Templates must use libraries that have been extended to accommodate the extended PresentationModel or Renderer. These extended libraries are also compliant with Open UI's architecture. All customizations are placed in extended libraries for easier upgrades. |
| Siebel Product Administration Guide | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
