Type.
SEFOS# configure terminal
SEFOS(config)# set gvrp disable
SEFOS(config)# set gmrp disable
SEFOS(config)# interface vlan 1
SEFOS(config-if)# shut
SEFOS(config-if)# ip address 10.7.0.6 255.255.0.0
SEFOS(config-if)# no shut
SEFOS(config-if)# exit
SEFOS(config)# vlan 1
SEFOS(config-vlan)# ports extreme-ethernet 0/1 untagged extreme-ethernet 0/1
SEFOS(config-vlan)# exit
SEFOS(config)# interface vlan 3
SEFOS(config-if)# ip address 10.5.6.6 255.255.255.0
SEFOS(config)# vlan 3
SEFOS(config-vlan)# ports extreme-ethernet 0/3 untagged extreme-ethernet 0/3
SEFOS(config)# interface extreme-ethernet 0/3
SEFOS(config-if)# switchport pvid 3
