SEFOS# configure terminal SEFOS(config)# set gvrp disable SEFOS(config)# set gmrp disable SEFOS(config)# interface vlan 1 SEFOS(config-if)# shut SEFOS(config-if)# ip address 10.8.0.7 255.255.0.0 SEFOS(config-if)# no shut SEFOS(config-if)# exit SEFOS(config)# vlan 1 SEFOS(config-vlan)# ports extreme-ethernet 0/1 untagged extreme-ethernet 0/1 SEFOS(config-vlan)# exit
