Configure the ASBR Router
Routers that act as gateways (redistribution)
between OSPF and other routing protocols (IGRP, EIGRP, RIP, BGP,
Static) or other instances of the OSPF routing process are called
ASBR. See Stub Area, ASBR, and Route Redistribution Topology Example for the topology for
this procedure.
- Enter
Global Configuration mode in SEFOS1.
SEFOS# configure terminal
- Enable OSPF globally in the switch
SEFOS1.
SEFOS(config)# router ospf
- Configure the OSPF router ID.
SEFOS(config-router)# router-id 10.10.2.1
- Configure the ASBR router.
SEFOS(config-router)# asbr router
