SEFOS# configure terminal SEFOS(config)# interface vlan 3
The IPv6 link-local address is automatically configured on the interface when you enable IPv6 processing in the interface. IPv6 support is disabled in an interface by default.
SEFOS(config-if)# ipv6 enable SEFOS(config-if)# exit SEFOS(config)# exit
SEFOS# show ipv6 interface vlan 3 vlan3 is up, line protocol is up IPv6 is Enabled Link local address: fe80::214:4fff:fe6c:560f Global unicast address(es): fec0::2222:0:1/96 ...
