SEFOS# configure terminal SEFOS(config)# interface vlan 1 SEFOS(config-if)# ipv6 enable
SEFOS(config-if)# ipv6 address fec0::1111:0:1/96
The default prefix type is set as unicast. You can configure the prefix type as anycast, eui64, or link-local address by defining the prefix type in the command.
SEFOS(config-if)# ipv6 address fe80::203:2ff:fe03:501 link-local SEFOS(config-if)# end
SEFOS# show ipv6 interface vlan 1 vlan1 is up, line protocol is up IPv6 is Enabled Link local address: fe80::203:2ff:fe03:501 Global unicast address(es): fec0::1111:0:1/96 ...
