Cloud computing provides a user with a virtual machine which is based on shared resources and services.
ES2 refers to an Oracle Ethernet Switch, such as the Oracle Switch ES2-72 and Oracle Switch ES2-64.
OpenStack supports these interfaces:
OpenStack UI, also known as Horizon
OpenStack CLI
OpenStack Rest API
L2 (Level 2) is one of seven levels in the OSI mode of the communications functions of a computing system. The model divides communication functions into seven abstract layers. Level 2 is the data link layer that links two directly connected nodes in a local area network (LAN).
Each networking mechanism is managed by an ML2 MechanismDriver. The MechanismDriver is responsible for taking the information established by the TypeDriver and ensuring that it is properly applied given the specific networking mechanisms that have been enabled.
Modular layer 2. See OpenStack Neutron ML2 plugin.
OpenStack is a free, open-source, cloud-computing software platform. The technology consists of a series of software modules that control pools of processing, storage, and networking resources.
OpenStack Neutron is the module for managing networks and IP addresses for OpenStack cloud-computing software.
The OpenStack Neutron Modular Layer 2 (ML2) plugin is a framework allowing OpenStack Neutron to simultaneously use different industry-standard Layer-2 solutions, including OpenvSwitch, linuxbridge, and HyperV L2.
The Oracle Ethernet Switch ML2 Mechanism Driver allows OpenStack installations to configure network connectivity for Oracle VMs on Oracle Ethernet Switches
This is an incompatible version of mechanism driver and is used only for installations of OpenStack on Oracle Virtual Networking (OVN) systems. This document deals with the Oracle Ethernet Switch ML2 Mechanism Driver for OpenStack Neutron instead of the OVN version.
To install OpenStack on OVM systems, refer to the Oracle Virtual Networking ML2 MechanismDriver for OpenStack Neutron Installation Guide.
An OpenStack plugin is a module that is designed to be easily replaced by a module that you have customized to investigate and test new software concepts.
A tenant network is a VLAN network for an Oracle VM that is connected to an Oracle Ethernet Switch.
