Go to main content
Oracle® Server X6-2 Installation Guide for Windows Server Operating Systems
Exit Print View
Updated: April 2016
Set Up the Local Console
  1. Connect a terminal to the serial management port (SER MGT) either directly or through a terminal emulator.
    Set the terminal device to 9600 baud, 8 bit, no parity, 1 stop bit.
  2. Press Enter on the terminal device to create a connection between the serial console and the Oracle ILOM SP.
    The Oracle ILOM login prompt appears.
  3. Log in to Oracle ILOM. At the login prompt, type your Oracle ILOM user name and password.
    The default Oracle ILOM user name is root and the password is changeme.
    The CLI prompt (->) appears.
  4. Connect to the host console. At the CLI prompt type:
    -> start /HOST/console
    The serial management port output is automatically routed to the server's host serial local console.
Related Information
