Siebel Business Process Framework: Task UI Guide > Developing a Task UI > Process of Creating a Task UI > Adding a Task Group to a ViewTo add a task group to a view, do the procedure described in one of the following topics: For more information, see Task Group. A number of factors determine how Siebel CRM displays a task UI in the task pane. For more information, see Task UI Does Not Display in the Task Pane. Adding a Task Group to a ViewThis topic describes how to add a task group to a view so that Siebel CRM displays it only in a specific view. For example, for a task UI that assists the user with creating a new opportunity, you can define the view so that the task group only displays in the task pane when the user is currently in the Opportunity List View. You can also limit display of the task group according to the Siebel application that is running in the Siebel client, such as Siebel Call Center.
Adding a Task Group to Multiple ViewsThis topic describes how to add a task group so that Siebel CRM displays it across multiple views. For example, you can add the task group to the Task Pane View for a task UI that assists the user with creating a new opportunity but where the user must access the task from across multiple views. To add a task group to multiple views
| Siebel Business Process Framework: Task UI Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
