Siebel Business Process Framework: Task UI Guide > Developing a Task UI > Process of Creating a Task UI >
Diagramming a Task UI
This task is a step in Process of Creating a Task UI. The Task Editor allows you to create a visual representation of the entire task UI, including decision points and conditional logic. You can define the details of each step when you add each step in the Task Editor, or you can finish the entire flow, and then enter these details. Siebel Tools automatically creates the start and end steps for you when you create a new task object. To diagram a task UI
- Open the Task Editor.
For more information, Opening the Task Editor.
- Add one or more logic steps to the task UI.
A task UI can include one or more steps that include some form of logic, such as a business service step, decision point, subtask step, Siebel operation step, and so on. More than one of each type of these steps can exist. For more information, see Adding a Step to a Task UI.
- Add connectors to define the task flow.
For more information, see Creating a Connector.
- Repeat Step 2 and Step 3 until you correctly connect every step that the task UI contains.
