Siebel Hospitality Guide > Managing Property-Specific Menus and Packages > Menu and Package Types Reference > Package Each ReferencePackage Each is the reverse of Package Item Price and similar to the Package Per Person. The Total Header Price is required, while the child line item prices do not roll up to the parent price. However, unlike the Package Per Person, all child line items of a Package Each must be of UoM is equal to Each. Example of a Package EachIn a Package Each, the Unit Net Price, Extended Price, Negotiated Price, Discount %, and Net Discount values apply only to the parent package. For child items, these values are not displayed and the fields are read only. Table 78 shows an example of a package each with an expected quantity of 10. Package Each Field BehaviorsThis topic describes the behaviors and internal calculations that Siebel Hospitality performs for selected fields in a Package Each and its child items. These behaviors are typical of the Package Each package type. Extended Quantity FieldBecause only static child line items exist in an Package Each package, the Extended Quantity for the parent package equals the Quantity. However, in each child line item, the Extended Quantity equals Parent Quantity multiplied by Child Quantity. Using values from Table 78, the Unit Net Prices are calculated as shown in Table 79. Unit Net Price FieldUnit Net Price is calculated as follows: If Negotiated Price is null, the calculation is one of the following: If Negotiated Price is not null, the calculation is one of the following: Using values from Table 78, the Unit Net Prices are calculated as shown in Table 80. Extended Net Price FieldThe Extended Net Price is calculated as Extended Quantity multiplied by Unit Net Price for both the parent package and the child line items. Using values from Table 78, the Unit Net Prices are calculated as shown in Table 81. Per Person Allocation FieldFor child items, the default value is the allocations value defined for the item by the administrator. You can update this value manually. Function Total FieldThe Function Total field is located in the function record. This field shows the total value of the function. The Function Total field value includes the Extended Net Price of the parent package, but not the Extended Net Prices of the child items. |
| Siebel Hospitality Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
