Siebel Hospitality Guide > Managing Property-Specific Menus and Packages > Menu and Package Types Reference > Menu Per Person, Set Price ReferenceThe Menu Per Person, Set Price menu type is used when you can estimate an expected number of guests. The calculations are different from a Menu Per Person, Split Price and are controlled by the Split flag value, which is set to N. In Menu Per Person, Set Price, Siebel Hospitality adds the menu prices together and displays them on a per person basis. Actual child line item quantities are reflected in the Extended Quantity fields. The child prices do not roll up to the parent price. Example of a Menu Per Person, Set PriceIn a Menu Per Person, Set Price, the Unit Net Price, Extended Price, Negotiated Price, Discount %, and Net Discount values apply only to the parent package. For child items, these values are not displayed and the fields are read only. Table 82 shows an example of a menu per person, set price with an expected quantity of 10. Menu Per Person, Set Price Field BehaviorsThis topic describes the behaviors and internal calculations that Siebel Hospitality performs for selected fields in a Menu Per Person, Set Price and its child items. These behaviors are typical of the Menu Per Person, Set Price menu type. Best Attendance FieldIf Actual is not null, Best Attendance is equal to Actual. If Actual is null and Guaranteed is not null, Best Attendance is equal to Guaranteed. If Actual and Guaranteed are null and Projected is not null, Best Attendance is equal to Projected. If Actual, Guaranteed, and Projected are all null, Best Attendance is equal to Expected. Extended Quantity FieldThe Extended Quantity is calculated as the Parent Quantity multiplied by the Item Quantity, where Parent Quantity is equal to Best Attendance, for each child line item regardless of its UOM. You can manually modify the Extended Quantity of the parent and its child items. For the parent package and static child line items, Siebel Hospitality does not perform this calculation, and Extended Quantity is the same as Quantity. Usually, all products associated with a Menu Per Person, Set Price have UOM is equal to Per Person. Using values from Table 82, the Unit Net Prices are calculated as shown in Table 83. Unit Net Price FieldUnit Net Price is calculated as follows: If Negotiated Price is null, the calculation is one of the following: If Negotiated Price is not null, the calculation is one of the following: Using values from Table 82, the Unit Net Prices are calculated as shown in Table 84. Extended Price FieldExtended Price is calculated as Extended Quantity multiplied by Unit Net Price for the parent menu. For the child line items, Extended Price is null and read only. Using values from Table 82, the Extended Price is calculated as shown in Table 85. Function Total FieldThe Function Total field is located in the function record. This field shows the total value of the function. The Function Total field value includes the Extended Net Price of the parent menu, but not the Extended Net Prices of the child items. |
| Siebel Hospitality Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
