Siebel Hospitality Guide > Setting Up Pricing and Property Pricing > Setting Up a Matrix Series >
Defining an Account Matrix Discount
Your company can award discounts to valued accounts that bring a large amount of business to the company. This might act as an incentive for the account to continue using your company for hospitality events.
This task is a step in Setting Up a Matrix Series.
To define an account matrix discount
  1. Navigate to the Property Pricing Admin screen, then the Properties view.
  2. In the Properties list, select the required property and click the link in the Property Name field.
  3. Click the Matrix Series view tab.
  4. In the Matrix Series list, create a new record, as described in Creating a Matrix Series for a Property.
  5. Scroll down and click the Account Matrix view tab.
  6. Create a number of new records as required, complete the fields, and save each record.
    The following table describes some of the fields.
    Field
    Comments
    Name
    Enter a name for the account matrix.
    Account Name
    Select the account to which this matrix will apply.
    Parent Account
    Select the parent account of the Account to which this discount will apply.
    Product
    Select the product to which this matrix will apply. Only products that are contained in the Product Line for the Matrix Series will be available for selection here if a Product Line is used for the series.
    Frequency
    Select the day of the week on which this matrix will apply.
    Adjustment Type
    Enter the type of adjustment. For information about the selection options, see About Matrix Discount Adjustment Types.
    Adjustment Amount
    The amount of the adjustment that is specified by type.
Siebel Hospitality Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
