Siebel Hospitality Guide > Setting Up Pricing and Property Pricing > Setting Up a Matrix Series >
Defining a Segment Matrix Discount
This task is a step in Setting Up a Matrix Series. To define a segment matrix discount
- Navigate to the Property Pricing Admin screen, then the Properties view.
- In the Properties list, select the required property and click the link in the Property Name field.
- Click the Matrix Series view tab.
- In the Matrix Series list, create a new record.
For more information about creating a matrix series record, see Creating a Matrix Series for a Property.
- Click the Segment Matrix view tab.
- Create a number of new records as required, complete the fields, and save the records.
The following table describes some of the fields.
Name |
The name of the account matrix. This field is automatically populated. |
Opportunity Segment |
Select the segment to which this matrix will apply. |
Product |
Select the product to which this matrix will apply. Only products that are contained in the Product Line for the Matrix Series will be available for selection here if a Product Line is used for the series. |
Frequency |
Select the day of the week on which this matrix will apply. |
Adjustment Type |
Enter the type of adjustment. For information about the selection options, see About Matrix Discount Adjustment Types. |
Adjustment Amount |
The amount of the adjustment that is specified by type. |
