Siebel Hospitality Guide > Setting Up Properties > Roadmap for Setting Up Hospitality PropertiesThis topic lists the procedures and processes that administrators typically perform to set up properties using Siebel Hospitality. Your company might follow a different process according to its business requirements. NOTE: This process is carried out as much as possible for nonparticipating properties (NPPs). That is, you must use all information available to you about NPPs to build the profiles of NPPs. For more information about NPPs, see Setting Up Nonparticipating Properties. To set up Hospitality properties, perform the following processes and tasks:
| Siebel Hospitality Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
