Siebel Hospitality Guide > User Properties Reference for Siebel Hospitality > User Properties for Histories and Futures >
Applet User Properties for Histories and Futures Functionality
This topic describes the following applet user properties:
Apply Custom Visibility
Use this user property to apply customized visibility rules.
Value |
Y |
Parent Object Type |
TNT History Opportunity List Applet applet |
Usage |
If this user property is set, then the visibility rules of the framework do not apply, but the customized visibility rules do apply. |
Default Aspect
Use this user property to define the Default Aspect property for an applet.
Value |
History |
Usage |
When the aspect is defined, the business component user properties function that is based on the aspect is defined. The Default Aspect is defined as History. |
Default Aspect
Value |
History |
TNT Opportunity History Assoc List Applet applet |
Usage |
Default Aspect
Value |
History |
TNT History Quote List Applet applet |
Usage |
Get Service Method
Use this user property to specify the service method to be called.
Value |
BuildVisibilitySearchSpec |
Usage |
If this user property is set, then the specified service method will be called to apply visibility in Histories and Futures. |
Get Service Name
Use this user property to specify the service to be called.
Value |
TNT Utility Service |
Usage |
If this user property is set, then the specified service will be called to apply visibility in Histories and Futures. |
