Siebel Hospitality Guide > User Properties Reference for Siebel Hospitality > User Properties for Histories and Futures >
Business Component User Properties for Histories and Futures
This topic describes the following business component user properties:
Activation BC 1
Use this user property to activate the fields of the business component specified in the user property value.
Value |
TNT History Quote |
Parent Object Type |
TNT History Opportunity business component |
Usage |
If this user property is available, then the fields of this business component are activated when the current view is not active. |
Activation BC 2
Value |
TNT History Functions |
Usage |
Activation BC 3
Value |
TNT History Room Blocks |
Usage |
Activation Fields
Use this user property to specify the fields to activate.
Values |
Name, Original Opportunity Name, Event Template Name, Account, Intermediary Account, Arrival Date, Departure Date, Opportunity Segment, Type, Locked Flag |
Usage |
If this user property is available, then the specified fields of the business component are activated when the current view is not active. |
Activation Fields
Use this user property to specify the fields to be activated.
Values |
Property Name, Property Type, Quote Number, Quote Name, Status, Arrival Date, Departure Date, Currency Code, Comments |
TNT History Quote business component |
Usage |
If this user property is available, then the specified fields of the business component will be activated when the current view is not active. |
Activation Fields
Values |
Start Date, Start Day, Function Name, # Actual, # Contracted, # Expected, # Guaranteed, Food Revenue, Beverage Revenue, Room Rental Revenue |
TNT History Functions business component |
Usage |
Activation Fields
Values |
Start Date, Start Day, Contracted, Blocked, 90 Day Pickup, 60 Day Pickup, 30 Day Pickup, Actual, Picked Up, Projected, Complimentary |
History Room Blocks business component |
Usage |
All Historical Opportunities
Use this user property to pass the name of the Historical Opportunity view that has All visibility.
Value |
TNT All Historical Opportunities View |
Usage |
If this user property is available, then apply All visibility. |
All Properties
Use this user property to pass the name of the Properties view that has All visibility.
Value |
TNT SHM All Property View |
Usage |
If this user property is available and the view is accessible, then apply All visibility. |
Apply Visibility Field
Use this user property to specify the field on which visibility is applied.
Value |
Property Id |
Usage |
If this user property is available, then this field determines the visibility application. |
Aspect BC ReadOnly: History
Use this user property to set the business component to read-only mode, if the value of the field specified in the user property is Y.
Value |
Calc Locked Flag |
Usage |
When Aspect is defined and the current aspect is Aspect, then the current record becomes read-only when the value of the specified field is Y. |
Value |
Calc Locked Flag |
Usage |
When Aspect is defined, and the current aspect is Aspect, then the current record becomes read-only when the value of Field Name is Y. |
Aspect Child BC ReadOnly: History
Value |
Calc Locked Flag |
Usage |
When Aspect is defined and the current aspect is Aspect, then the child business components of the current record become read-only when the value of the specified field is Y. |
Value |
Calc Locked Flag |
Usage |
When Aspect is defined, and the current aspect is Aspect, then the child business components of the current record become read-only when the value of Field Name is Y. |
Cluster BC
Use this user property to specify the business component name used in the Clusters view.
Value |
TNT SHM Cluster |
Usage |
If this user property is available, then while applying visibility, the cluster-related data configured for a specific logged-in user is retrieved from this business component. |
Cluster BO
Use this user property to specify the business object name used in the Clusters view.
Value |
TNT SHM Cluster |
Usage |
If this user property is available, then while applying visibility, the cluster-related data configured for a specific logged-in user is retrieved from the business component available in this business object. |
Clusters
Use this user property to pass the name of the Properties view that has Cluster visibility.
Value |
TNT SHM All Property by Cluster View |
Usage |
If this user property is available and the view is accessible, then apply Cluster visibility. |
Clusters Historical Opportunities
Use this user property to pass the name of the Historical Opportunity view that has Cluster visibility.
Value |
TNT My Cluster Historical Opportunities View |
Usage |
If this user property is available, then apply Cluster visibility. |
Deep Copy 1
Use this user property to copy the specified child business component when a user selects the Copy option.
Value |
Usage |
When this property is set when a user chooses Copy Record in the parent business component, the specified child business component is also copied. |
Deep Copy 2
Value |
Usage |
Deep Delete 1
Use this user property to delete the specified child business component when a user selects the Delete option.
Value |
Usage |
When this property is set when a user chooses Delete Record in the parent business component, the specified child business component is also deleted. |
Deep Delete 2
Value |
Usage |
Employee BC
Use this user property to specify the business component name used in the Administration - User screen, Employees and Users views.
Value |
Employee |
Usage |
If this user property is available, then while applying visibility, the employee-related data and user-related data of the logged-in user are retrieved from this business component. |
Employee BO
Use this user property to specify the business object name used in the Administration - User screen, Employees and Users views.
Value |
Employee |
Usage |
If this user property is available, then while applying visibility, the employee-related data and user-related data of the logged-in user are retrieved from the business component available in this business object. |
Event Template Id
Use this user property to set the Row Id of a template when working with templates.
Value |
Event Template Id |
Usage |
If this user property is available when an event template is applied to an opportunity, set the Template Id of Event Template to the business component field name. |
Field Read Only Field: Locked Flag
Use this user property to set only the specified field to read-only mode. The value of the user property determines if the specified field is set to read-only mode.
Value |
Calc Locked Flag Read Only |
Usage |
If this user property is set, then the field name after the colon (:) in the user property name is read only. The value of the user property determines if this field is read only. |
My Historical Opportunities
Use this user property to pass the name of the Historical Opportunity view that has My visibility.
Value |
TNT My Historical Opportunities View |
Usage |
If this user property is available, then apply My visibility. |
My Properties
Use this user property to pass the name of the Properties view that has My visibility.
Value |
TNT SHM My Property View |
Usage |
If this user property is available and the view is accessible, then apply My visibility. |
On Field Update Invoke
Use this user property to call the specified business component method when a field is updated.
Values |
History Opportunity Id, TNT Opportunity History Assoc, UpdateLinks |
TNT Opportunity History Assoc business component |
Usage |
When the History Opportunity Id field is updated, then the Update Links method of the business component is called. |
Parent Pick Field
Use this user property to set the Template Id to an opportunity field when applying an event template to an opportunity.
Value |
Name |
TNT SHM Opportunity Property business component |
Usage |
If this user property is available when an event template is applied to an opportunity, set the property from Event Template to the business component field name. |
Parent Pick Field
Use this user property to specify the name of the field that has an associated picklist.
Value |
Name |
Usage |
When creating or applying an event template, copies the name of the field with the associated picklist that includes all the details of the selected record, rather than copying all the fields. |
Property BC
Use this user property to specify the business component name used in the Property view.
Value |
SHM Site |
Usage |
If this user property is available, then while applying visibility, the property-related data configured for a specific logged-in user is retrieved from this business component. |
Skip Setup Style Initialization
Use this user property to skip the setup style initialization, which is the initialization that occurs when a control is loaded into your Siebel application, for the Function Space Diary.
Value |
Y |
TNT SHM FSI Room Relationships business component |
Usage |
Setup style initialization is necessary only the first time the Function Space Diary screen is loaded. Activating this user property avoids subsequent initializations. This user property is used in C++ code to improve performance when the Function Space Diary control is loaded into Siebel Hospitality. The default value is Y, which prevents the Function Space Diary control from being initialized when it is loaded into Siebel Hospitality. If the value is N, then the Function Space Diary control is initialized each time it is loaded into Siebel Hospitality. |
Template Copy Fields
Use this user property to copy field values from a template when working with templates.
Value |
Property Id |
Usage |
If this user property is available when an event template is applied to an opportunity, set the Property Id from Event Template to the business component field name. |
Example |
TNT SHM Brand, TNT SHM City |
Use this user property to copy the specified field values from a template.
Value |
History Opportunity Id |
Usage |
If this user property is available, then the History Opportunity Id field is copied from the event template to the record to which the event template is applied. |
