Siebel Hospitality Guide > User Properties Reference for Siebel Hospitality > User Properties for Banquet Event Order Report >
Applet User Properties for Banquet Event Order Reports
This topic describes the following applet user properties:
IsSearchSpecFldMVG
Use this user property to designate if the search specification field in the SearchSpecField user property is a MVG (Multi-Value Group) field.
Value |
N |
Parent Object Type |
TNT SHM Report Section MVG Applet applet |
Usage |
Designates if the search specification field in the SearchSpecField user property is a MVG (Multi-Value Group) field. |
Named Method 1: DeleteRecord
Use this user property to recalculate the Split Qty Flag for the parent line item when a user deletes a child line item.
Value |
'INVOKE', 'DeleteRecord' |
TNT SHM Function Line Items List Applet, TNT SHM Order Line Item List Applet, TNT SHM Event Check Line Item List Applet, and TNT SHM Event Check Order Line Item Form Applet applets |
Usage |
Recalculates the Split Qty Flag for the parent line item when a user deletes a child line item. This user property works with the Named Method 2: DeleteRecord user property. |
Value |
'INVOKE', 'SetParentSplitFlag' |
Usage |
Recalculates the Split Qty Flag for the parent line item when a user deletes a child line item. This user property works with the Named Method 1: DeleteRecord user property. |
SearchSpecField
Use this user property to prepare the search specification.
Value |
PS Property Id |
Usage |
Prepares the search specification. This user property is used in C++ code, and works with the IsSearchSpecFldMVG user property. |
