Siebel Hospitality Guide > User Properties Reference for Siebel Hospitality > User Properties for Banquet Event Order Report >
Business Component User Properties for Banquet Event Order Reports
This topic describes the following business component user properties:
Copy Function Calculate Price: Quote
Use this user property to designate that the price must be calculated for line items when users copy a function.
Value
Y
Parent Object Type
TNT SHM Function business component
Usage
This user property is used in C++ code and created with the business object. If the active business object is Quote, then the price must be calculated for line items when users copy a function.
Disable Hierarchy: SHM Invoice
This user property is used in C++ code to disable or enable the function hierarchy in the active business object when the Day number (#) field and Date field for the function change.
Value
Y
Parent Object Type
Usage
Disable Hierarchy: TNT SHM Order Entry
Value
Y
Parent Object Type
Usage
Field Read Only Field: Date
Use this user property to set the Date field for subfunctions to a read-only mode.
Value
Is Sub Function Flag
Parent Object Type
Usage
Sets the Date field for subfunctions to a read-only mode.
Field Read Only Field: Day#
Use this user property to set the Day number (#) field for subfunctions to a read-only mode.
Value
Parent Object Type
Usage
Sets the Day number (#) field for subfunctions to a read-only mode.
Value
DateReadOnlyFlag
Parent Object Type
TNT SHM Agenda Functions business component
Usage
Field Read Only Field: Start Date
Use this user property to set the Start Date field for subfunctions to a read-only mode.
Value
DateReadOnlyFlag
Parent Object Type
Usage
Sets the Start Date field for subfunctions to a read-only mode.
IsSearchSpecFldMVG
Use this user property to designate if the search specification field in the SearchSpecField user property is a MVG (Multi-Value Group) field.
Value
N
Parent Object Type
TNT SHM Property Report Section business component
Usage
Designates if the search specification field in the SearchSpecField user property is a MVG (Multi-Value Group) field.
Menu Item Field Map 7
Use this user property to copy the report header value for child items in product and property administration to quote line items.
Value
"TNT Product Report Header Id", "Report Header Id"
Parent Object Type
TNT SHM Quote Item business component
Usage
Copies the report header value for child items in product and property administration to quote line items.
Use this user property to copy the report header value for child items in product and property administration to order line items.
Value
"TNT Report Section Id", "Report Header Id"
Parent Object Type
TNT SHM Order Item business component
Usage
Copies the report header value for child items in product and property administration to order line items.
Named Method 1
Use this user property to update the projected revenue for revenue estimates when the Projected, Expected, and Guaranteed fields for a function change.
Value
"Update Revenue", "INVOKE", "TNT SHM Quote Function Revenue Estimates", "ExpandAll"
Parent Object Type
TNT SHM Quote Function Revenue Estimates business component
Usage
Updates the projected revenue for revenue estimates when the Projected, Expected, and Guaranteed fields for a function change. This user property works with the Named Method 2 and Named Method 3 user properties.
Named Method 2
Value
"Update Revenue", "INVOKEALL", "TNT SHM Quote Function Revenue Estimates", "Set Revenue"
Parent Object Type
Usage
Updates the projected revenue for revenue estimates when the Projected, Expected, and Guaranteed fields for a function change. This user property works with the Named Method 1 and Named Method 3 user properties.
Named Method 3
Value
"Set Revenue", "SET", "Projected Revenue - Function", "[Projected Revenue Per Person] * [Parent Attendees Calc]"
Parent Object Type
Usage
Updates the projected revenue for revenue estimates when the Projected, Expected, and Guaranteed fields for a function change. This user property works with the Named Method 1 and Named Method 2 user properties.
Named Method 3
Use this user property to update the Day number (#) field and Date field for the associated subfunctions when the same fields for a function change.
Value
"Update Sub Function", "INVOKESVC", "TNT SHM Agenda Functions", "TNT SHM Day Number", "UpdateSubFunction"
Parent Object Type
Usage
Updates the Day number (#) field and Date field for the associated subfunctions when the same fields for a function change. This user property works with the On Field Update Invoke 1 user property.
Named Method 11
Value
"Update Sub Function", "INVOKESVC", "TNT SHM Function", "TNT SHM Day Number", "UpdateSubFunction"
Parent Object Type
Usage
Updates the Day number (#) field and Date field for the associated subfunctions when the same fields for a function change. This user property works with the On Field Update Invoke 19 user property.
Value
"Day #", "TNT SHM Agenda Functions", "Update Sub Function", "[Child Function Id] IS NOT NULL"
Parent Object Type
Usage
Updates the Day number (#) field and Date field for the associated subfunctions when the same fields for a function change. This user property works with the Named Method 3 user property.
On Field Update Invoke 16
Use this user property to update the projected revenue for revenue estimates when the Projected field for a function changes.
Value
"Projected Num", "TNT SHM Quote Function Revenue Estimates", "Update Revenue", "[Guaranteed Num] IS NULL"
Parent Object Type
Usage
Updates the projected revenue for revenue estimates when the Projected field for a function changes.
On Field Update Invoke 17
Use this user property to update the projected revenue for revenue estimates when the Guaranteed field for a function changes.
Value
"Guaranteed Num", "TNT SHM Quote Function Revenue Estimates", "Update Revenue"
Parent Object Type
Usage
Updates the projected revenue for revenue estimates when the Guaranteed field for a function changes.
On Field Update Invoke 18
Use this user property to update the projected revenue for revenue estimates when the Expected field for a function changes.
Value
"Expected Num", "TNT SHM Quote Function Revenue Estimates", "Update Revenue", "[Guaranteed Num] IS NULL AND [Projected Num] IS NULL"
Parent Object Type
Usage
Updates the projected revenue for revenue estimates when the Expected field for a function changes.
Value
"Day#", "TNT SHM Function", "Update Sub Function", "[Child Function Id] IS NOT NULL"
Parent Object Type
Usage
Updates the Day number (#) field and Date field for the associated subfunctions when the same fields for a function change. This user property works with the Named Method 11 user property.
On Field Update Set
Use this user property to capture in the Revision Time field the date and time that the track changes flag changes.
Value
"Track Changes Flag", "Revision Time", "IIf ([Track Changes Flag]= 'Y', Timestamp(), '')"
Parent Object Type
Order Entry - Orders business component
Usage
Captures in the Revision Time field the date and time that the track changes flag changes.
On Field Update Set 1
Use this user property to set the default value for the report header label to the report header name.
Value
"Report Section", "Display Name", "[Report Section]"
Parent Object Type
Usage
Sets the default value for the report header label to the report header name.
Package Item Field Map 6
Value
Parent Object Type
Usage
Value
Parent Object Type
Usage
SearchSpecField
Use this user property to prepare the search specification.
Value
Parent Property Id
Parent Object Type
Usage
Prepares the search specification. This user property is used in C++ code, and works with the IsSearchSpecFldMVG user property.
Sequence Field
Use this user property to get a sequence number when users create a new record.
Value
Sequence Num
Parent Object Type
TNT Function Report Comments and TNT SHM BEO Section Description business components
Usage
Gets a sequence number when users create a new record.
Template Copy Fields
Use this user property to specify the copied fields when users create a template for a function.
Value
Day#, Function Type, Function Name, Start, Duration, End, Setup Style, Expected Num, Function Space, Post As, Comments, Projected Num, Room Area, Room Area Square Meters, Meal Period, Flow Flag, Spacious Set Flag, Noise Flag, Best Fit Suite Only, TNT SubFunction Location
Parent Object Type
Usage
Specifies the copied fields when users create a template for a function.
Use this user property to specify the copied fields when users create a template for an agenda function.
Value
Day #, Function Type, Name, Start Time, Duration, End Time, Setup Style, Expected #, Projected, Room Area, Room Area Square Meters, Meal Period, Flow Flag, Spacious Set Flag, Noise Flag, Bypass Flag, Best Fit Suite Only Flag, Location
Parent Object Type
Usage
Specifies the copied fields when users create a template for an agenda function.
Siebel Hospitality Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
