Siebel Hospitality Guide > User Properties Reference for Siebel Hospitality >
User Properties for Run of House
This topic describes the user properties supported for the Run of House functionality of Siebel Hospitality. This topic describes the following user properties:
AddSellNoteRowOnTop
Use this user property to decide the position for displaying sell notes.
Value |
Y |
Parent Object Type |
TNT SHM SR Inventory Dync, TNT SHM SR Total Avail Dync, TNT SHM SR Total Transient Avail Dync, TNT SHM SR Type Dync - Group By Type business components |
Usage |
This user property is used to decide the position for displaying sell notes. If the value is Y, then the sell notes are displayed at the top of the Total Group Availability applet. If the value is not Y, then the sell notes are displayed at the end of Total Group Availability applet. In the later case, above the sell notes, counts are displayed for Total Group Available, Group Optimal, Group Blocked, Group Projected, and Group Authorized for the different room types. |
Pivot 0 BC Sort Spec
Use this user property to define the sort specification while displaying the available data.
Value |
Start Date, Room Type (DESCENDING), Room Name |
TNT SHM SR Inventory Dync business component |
Usage |
This user property is used to define the sort specification while displaying the available data. The sort specification can be changed by modifying the value with appropriate fields. |
ROH Main Search Spec Field Name
Use this user property to check the availability functionality for Run of House rooms.
Value |
ROH Main Search Spec |
TNT SHM Quote Room Block Summary DyncPivot, TNT SHM Revised Room Block Booking, TNT SHM Quote Room Block Line Items, TNT SHM FSI Booking business components |
Usage |
This user property is used in conjunction with the ROH Sub Search Spec Field Name user property. This user property is used to check the availability of Run of House rooms. |
Value |
ROH Sub Search Spec |
Usage |
This user property is used in conjunction with the ROH Main Search Spec Field Name user property. This user property is used to check the availability of Run of House rooms. |
