Siebel Hospitality Guide > User Properties Reference for Siebel Hospitality >
User Properties for Sleeping Room Taxes and Service Charges
This topic describes the user properties supported for the Sleeping Room Taxes and Service Charges functionality of Oracle's Siebel Hospitality. This topic describes the following business component user properties:
Calculate Tax & Service Charges for Room
Use this user property to determine whether or not to calculate taxes and service charges for sleeping rooms.
Value |
Y |
Parent Object Type |
TNT SHM Room block Rates, TNT SHM Room block Rates Pending business components |
Usage |
This user property is used to decide whether or not to calculate taxes and service charges for sleeping rooms. This user property has a value of Y to calculate taxes and service charges, and a value of N to not to calculate taxes and service charges. |
Consider Complimentary
Use this user property to determine whether or not the complimentary quantity must be considered when negotiated sleeping rooms records are generated.
Value |
Function Status;Quote Status |
Usage |
This user property is used to decide whether or not the complimentary quantity must be considered when negotiated sleeping rooms records are generated. This user property has a value of Y to consider the complimentary quantity, and a value of N to not consider the complimentary quantity. |
TNT SHM Calc Revenue For Which Field
Use this user property to indicate which amount taxes and service charges must be calculated for.
Value |
ForAdjusted |
Usage |
This user property is used to indicate which amount taxes and service charges must be calculated for. The default ForAdjusted value calculates the sum of taxes and service charges for the guest invoice. The ForOriginal value calculates the sum of taxes and service charges for the accounting invoice. |
TNT SHM Total Service Charge Amount Field
Use this user property to indicate the name of the field in which the weekday service charge amount is stored.
Value |
Service Charge Amount |
Usage |
This user property is used to indicate the name of the field in which the weekday service charge amount is stored. |
TNT SHM Total Tax Amount Field
Use this user property to indicate the name of the field in which the weekday tax amount is stored.
Value |
Tax Amount |
Usage |
This user property is used to indicate the name of the field in which the weekday tax amount is stored. |
TNT SHM Weekend Total Service Charge Amount Field
Use this user property to indicate the name of the field in which the weekend service charge amount is stored.
Value |
Weekend Service Charge Amount |
Usage |
This user property is used to indicate the name of the field in which the weekend service charge amount is stored. |
TNT SHM Weekend Total Tax Amount Field
Use this user property to indicate the name of the field in which the weekend tax amount is stored.
Value |
Weekend Tax Amount |
Usage |
This user property is used to indicate the name of the field in which the weekend tax amount is stored. |
