Siebel Hospitality Guide > User Properties Reference for Siebel Hospitality > User Properties for Meeting Packages >
Applet User Properties for the Function Space Diary
This topic describes the user properties that support meeting packages functionality in the Function Space Diary applets:
Diary User Preferences for End Time
This user property is used to specify the field name that is used in the Diary user preferences for end time control.
Value |
End Time |
Parent Object Type |
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary, and TNT SHM Function Space Diary Total Availability Applet |
Usage |
This user property specifies the field name that is used in the Diary user preferences for end time control. |
Diary User Preferences for Start Time
This user property is used to specify the field name that is used in the Diary user preferences for start time control.
Value |
Start Time |
Usage |
This user property specifies the field name that is used in the Diary user preferences for start time control. |
Item Color Fields
This user property is used to specify the field name that is present in the Y-axis business component in the Diary.
Value |
Compound Inventory Status |
Usage |
This user property specifies the field name that is present in the Y-axis business component in the Diary. The booking color is displayed in the Diary according to the value of this user property. |
Item Mouse Over Ids
This user property is used to control the cursor shape in the Diary when the mouse pointer is hovering.
Value |
213;213;213;213 |
Usage |
This user property specifies the parameter for the cursor shape in the Diary when the mouse pointer is hovering. |
Item Time TurnTime Toggle BC Method
This user property is used to specify the name of the business component method that displays the turn time conflicts, if any, within the booking.
Value |
ShowToggleTurnTime |
Usage |
This user property displays the name of the business component method that displays the turn time conflicts, if any, within the booking. |
Restrict Diary BC Date
This user property is used to set the effective dates search specification in the booking business component and display the appropriate active specific spaces.
Value |
Y |
Usage |
If this user property is set to Y, then it sets the effective dates search specification in the booking business component and displays the appropriate active specific spaces. |
Retain Unreserve Popup Default
If the timing for a primary booking is changed, then this user property is used to move the booking to the new time.
Value |
Unreserve |
Usage |
If the timing for a primary booking is changed, then the primary booking is moved to the new time. If a backup space is booked, then this popup provides the option either to retain the backup booking or Unreserve it. |
Retain Unreserve Popup Name
This user property is used to specify the pop-up applet name for Retain Unreserve Popup Default.
Value |
TNT SHM Retain/Unreserve Popup Applet |
Usage |
This user property specifies the pop-up applet name for Retain Unreserve Popup Default. |
Transient Suite Field
This user property is used to disable the right-click context menu if the Type value of a space is Suite.
Value |
Is Transient Suite |
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary |
Usage |
This user property is used to disable the right-click context menu if the Type value of a space is Suite. |
Views Having No Space for Icons in Major Axis
This user property is used to list views that have no space for icons.
Value |
128;256 |
Usage |
This user property contains a semicolon (;) separated list of views that have no space to display icons. |
Weekend BC Activation Field 1
This user property is used to specify the name of a field in the Weekend Admin business component that is activated in the code.
Value |
Day of Week |
Usage |
This user property specifies the name of a field in the Weekend Admin business component that is activated in the code. |
Weekend BC Activation Field 2
Value |
Weekend Weekday Flag |
Usage |
Weekend BC Activation Field 3
Value |
Property Id |
Usage |
Y-Axis Drill Down Enable
This user property is used to enable or disable drill-down on Y-axis specific spaces.
Value |
N |
Usage |
If the value of this user property is N, then drill-down on Y-axis specific spaces is disabled. |
Y-Axis Mouse Over Cursor Ids
This user property is used to control the cursor shape on the Y-axis when the mouse pointer is hovering.
Value |
213;213;213;213 |
Usage |
This user property specifies the parameter for the cursor shape on the Y-axis when the mouse pointer is hovering. |
