Siebel Hospitality Guide > User Properties Reference for Siebel Hospitality > User Properties for Meeting Packages >
Business Component User Properties for the Function Space Diary
This topic describes the user properties that support meeting packages functionality in the Function Space Diary business components:
Activation Field 2
This user property is used to specify the fields to be activated in the business component when the Diary is initialized.
Value |
Function Space Type - Query |
Parent Object Type |
TNT SHM Gantt AX Date Time Interval PopUp VBC business component |
Usage |
This user property is used to specify the fields to be activated in the TNT SHM Gantt AX Date Time Interval PopUp business component, in the Function Space Diary screen, when the Diary applet is initialized. |
Color Code Weekend Type
Use this user property to define the type of day to which the Weekend color code type is mapped in the Function Space Diary.
Value |
Weekend |
Usage |
Each color code type has a different color, and each color must be mapped to a particular day type to identify those days in the Function Space Diary. The default value is Weekend. |
Default Function Space Type
This user property is used to provide the default value for the Function Space Type field.
Value |
Specific Space |
Usage |
This user property is used to provide the default value for the Function Space Type field. |
Default Start Date Time
This user property is used to provide the default value for the Start Date field.
Value |
Null |
TNT SHM Gantt AX Date Time Interval PopUp VBC business component TNT SHM Inventory Gantt AX Date Time Interval For Order PopUp VBC business component TNT SHM Inventory Gantt AX Date Time Interval PopUp VBC business component |
Usage |
This user property is used to provide the default value for the Start Date field. If this value is empty, then the default value of this field is the Date Threaded field value, if any. Otherwise, the default value of the Start Date field is the current date. |
Editable for TimeScale
This user property is used to specify whether or not the bookings are editable in each time scale.
Value |
1;N;2;N;4;Y;8;Y;16;Y;32;N;64;N;128;N;256;N |
Usage |
This user property is used to specify whether or not the bookings are editable in each time scale. |
GRC View:TNT SHM Site Function Space Diary Total Availability View
This user property is used to specify whether or not to refresh the other applets in the Function Space Diary views. This user property is used in conjunction with the Item BC Search Space applet user property.
Value |
Y |
Usage |
This user property is used to specify whether or not to refresh the other applets in the Function Space Diary views. This user property is used in conjunction with the Item BC Search Space applet user property. |
Parent StartDate Field
This user property is used to specify the Start Date field name in the parent business component.
Value |
Start Date |
Usage |
This user property specifies the Start Date field name in the parent business component. |
Time Part BC Major
This user property is used to specify the list of values in which day parts are displayed. Use this user property to retrieve the time part details for a property in the Function Space Diary.
Value |
Null |
Usage |
This user property is used to specify the list of values in which day parts are displayed. This user property retrieves the time part details for a property, and indicates whether or not to display the time part details on the appropriate time scale in the Function Space Diary. |
Time Part BC Minor End Date Field
Use this user property to retrieve the End Date for which to retrieve the time part details from the TNT SHM Property Day Part Pricing business component.
Value |
End Date |
Usage |
This user property retrieves the End Date for which to retrieve the time part details from the TNT SHM Property Day Part Pricing business component. The default value is End Date, which is a field in the TNT SHM Property Day Part Pricing business component. |
Time Part BC Minor End Time Field
Use this user property to retrieve the End Time for which to retrieve the time part details from the TNT SHM Property Day Part Pricing business component.
Value |
End Time |
Usage |
This user property retrieves the End Time for which to retrieve the time part details from the TNT SHM Property Day Part Pricing business component. The default value is End Time, which is a field in the TNT SHM Property Day Part Pricing business component. |
Time Part BC Minor Name Field
Use this user property to retrieve the Name for which to retrieve the time part details from the TNT SHM Property Day Part Pricing business component.
Value |
Name |
Usage |
This user property retrieves the Name for which to retrieve the time part details from the TNT SHM Property Day Part Pricing business component. The default value is Name, which is a field in the TNT SHM Property Day Part Pricing business component. |
Time Part BC Minor Start Date Field
Use this user property to retrieve the Start Date for which to retrieve the time part details from the TNT SHM Property Day Part Pricing business component.
Value |
Start Date |
Usage |
This user property retrieves the Start Date for which to retrieve the time part details from the TNT SHM Property Day Part Pricing business component. The default value is Start Date, which is a field in the TNT SHM Property Day Part Pricing business component. |
Time Part BC Minor Start Time Field
Use this user property to retrieve the Start Time for which to retrieve the time part details from the TNT SHM Property Day Part Pricing business component.
Value |
Start Time |
Usage |
This user property retrieves the Start Time for which to retrieve the time part details from the TNT SHM Property Day Part Pricing business component. The default value is Start Time, which is a field in the TNT SHM Property Day Part Pricing business component. |
TimeScale:Day/Day-Part
This user property is used to specify the number of days to be added to determine the date range columns for the Total Availability view.
Value |
1 |
TNT SHM SR Inventory Dync business component |
Usage |
This user property specifies the number of days to be added to determine the date range columns for the Total Availability view. |
TimeScale:Day/Half-Hour
Value |
1 |
Usage |
TimeScale:Day/Hour
Value |
1 |
Usage |
TimeScale:Day/Quarter-Hour
Value |
1 |
Usage |
TimeScale:Month/Day
Value |
1 |
Usage |
TimeScale:Month/Day-of-Week
Value |
7 |
Usage |
TimeScale:Month/Day-of-Week/Day Part
Value |
7 |
Usage |
TimeScale:Week/Day
Value |
1 |
Usage |
TimeScale:Week/Day/Day Part
Value |
1 |
Usage |
TNT SHM Site Function Space Diary Total Availability View:BC 1
If a user navigates to the TNT SHM Site Function Space Diary Total Availability View, then this user property refreshes the TNT SHM SR Inventory Dync business component.
Value |
TNT SHM SR Inventory Dync |
Usage |
If a user navigates to the TNT SHM Site Function Space Diary Total Availability View, then this user property refreshes the TNT SHM SR Inventory Dync business component. |
Total Availability Applet Name
This user property is used to provide the Total Availability applet name.
Value |
TNT SHM SR Inventory Display Dync List Applet - Total Availability |
Usage |
This user property provides the Total Availability applet name. |
Use Working Hours
This user property is used to specify whether or not to use working hours in each time scale.
Value |
Usage |
This user property specifies whether or not to use working hours in each time scale. If working hours are used, the horizontal scroll position is set depending on the start time of the working day and the pixels per unit. If working hours are not used, the horizontal scroll position is set to zero. |
X-Axis Drill Down Enable
This user property is used to specify whether or not to set the field value of Drilldown Name.
Value |
Y |
Usage |
This user property specifies whether or not to set the field value of Drilldown Name. |
