Siebel Hospitality Guide > User Properties Reference for Siebel Hospitality > User Properties for Arrival Date Modifications >
Applet User Properties for Arrival Date Modifications
This topic describes the following applet user property:
Named Method: ShowDatePopup
This user property allows you to call an applet method, on the call of the ShowDatePopup method on the applet.
Value |
INVOKE, ShowPopup, TNT SHM Arrival Date Popup Applet, Edit |
Parent Object Type |
Opportunity List Applet, Quote List Applet, TNT SHM Affiliate Opportunity List Applet, and TNT SHM Cluster Quote List Applet applets |
Usage |
This user property allows you to call the ShowPopup applet method, with the pop-up applet name and applet mode as arguments, to launch the pop-up applet on the call of the ShowDatePopup method. This method is called when a user clicks the Modify Arrival Date applet method menu item. |
