Siebel Hospitality Guide > User Properties Reference for Siebel Hospitality > User Properties for Arrival Date Modifications >
Business Component User Properties for Arrival Date Modifications
This topic describes the following business component user properties:
Arrival Date BC Name
The value of this user property contains the name of the field that holds the business component name to be used for booking during a change to the arrival date. This user property is used in C++ code.
Value |
TNT SHM Function |
Parent Object Type |
TNT SHM Function business component |
Usage |
The value of this user property contains the name of the field that holds the business component name to be used for booking during a change to the arrival date. This user property is used in C++ code for arrival date modifications functionality. |
Value |
TNT SHM Quote Room Block Line Items |
TNT SHM Quote Room Block Line Items business component |
Usage |
Arrival Date Popup Applet
This user property value contains the name of the pop-up applet that is used for function instructions. This user property is used in C++ code.
Value |
TNT SHM Arrival Date Popup Applet |
Opportunity, TNT SHM Affiliate Opportunity, TNT SHM Sub Opportunity, and Quote business components |
Usage |
The value of this user property contains the name of the pop-up applet that is used for function instructions. This user property is used in C++ code for arrival date modifications functionality. |
Arrival Date SearchSpec
The value of this user property contains the searchspec string to be applied to the TNT SHM Function business component to filter the functions that are frozen during a change to the arrival date. This user property is used in C++ code.
Value |
[Freeze Flag] <> 'Y' |
Usage |
The value of this user property contains the searchspec string to be applied to the TNT SHM Function business component to filter the functions that are frozen during a change to the arrival date. This user property is used in C++ code for arrival date modifications functionality. |
Day Number: Room Block Refresh BC Name
This user property passes the room block-related business component names to be refreshed during a change to the arrival date. This user property is used in C++ code.
Value |
TNT SHM Room Block;TNT SHM Oppty Rapid Room Block Capture Line Items |
Opportunity business component |
Usage |
This user property passes the room block-related business component names to be refreshed during a change to the arrival date. The value TNT SHM Oppty Rapid Room Block Capture Line Items is appended to the existing value. This user property is used in C++ code for arrival date modifications functionality. |
Field Name: Arrival Date
This user property value contains the name of the field that is used for the arrival date. This user property is used in C++ code.
Value |
Hospitality Start Date |
Opportunity, TNT SHM Affiliate Opportunity, and TNT SHM Sub Opportunity business components |
Usage |
The value of this user property contains the name of the field that is used for the arrival date. This user property is used in C++ code for arrival date modifications functionality. |
Value |
Arrival Date |
Quote business component |
Usage |
Field Name: ChildFuncBCToRefresh
The value of this user property contains the name of the field that holds the function agenda-related business component name to be refreshed during a change to the arrival date. This user property is used in C++ code.
Value |
ChildFuncBCToRefresh |
TNT SHM Affiliate Opportunity and TNT SHM Sub Opportunity business components |
Usage |
The value of this user property contains the name of the field that holds the function agenda-related business component name to be refreshed during a change to the arrival date. This user property is used in C++ code for arrival date modifications functionality. |
Field Name: ChildRoomBcToRefresh
The value of this user property contains the name of the field that holds the room block line items-related business component name to be refreshed during a change to the arrival date. This user property is used in C++ code.
Value |
ChildRoomBcToRefresh |
Usage |
The value of this user property contains the name of the field that holds the room block line items-related business component name to be refreshed during a change to the arrival date. This user property is used in C++ code for arrival date modifications functionality. |
Field Name: Function Instructions
This user property value contains the name of the field that is used for function instructions. This user property is used in C++ code.
Value |
Function Instructions |
Opportunity, TNT SHM Affiliate Opportunity, TNT SHM Sub Opportunity, Quote, and TNT SHM Arrival Date VBC business components |
Usage |
The value of this user property contains the name of the field that is used for function instructions. This user property is used in C++ code for arrival date modifications functionality. |
Field Name: RoomBlock Instructions
This user property value contains the name of the field that is used for room block instructions. This user property is used in C++ code.
Value |
RoomBlock Instructions |
Usage |
The value of this user property contains the name of the field that is used for room block instructions. This user property is used in C++ code for arrival date modifications functionality. |
Shift Functions
This user property is used to send instructions to the code as to whether or not to shift functions during the in-line modification of an arrival date. The default value is Y.
Value |
Y or N |
Usage |
This user property is used to send instructions to the code as to whether or not to shift functions during the in-line modification of an arrival date. This user property is used in C++ code. The default value is Y. |
Shift RoomBlocks
This user property is used to send instructions to the code as to whether or not to shift room blocks during the in-line modification of an arrival date. The default value is Y.
Value |
Y or N |
Usage |
This user property is used to send instructions to the code as to whether or not to shift room blocks during the in-line modification of an arrival date. This user property is used in C++ code. The default value is Y. |
Shift SubOpportunities
This user property is used to send instructions to the code as to whether or not to shift subopportunities during the in-line modification of an arrival date. The default value is Y.
Value |
Y or N |
Usage |
This user property is used to send instructions to the code as to whether or not to shift subopportunities during the in-line modification of an arrival date. This user property is used in C++ code. The default value is Y. |
Sub Opportunity SearchSpec
The value of this user property contains the searchspec string to be applied to the Opportunity business component to retrieve the subopportunities during a change to the arrival date. This user property is used in C++ code.
Value |
[Relationship Type LIC] = 'Sub-Recurrence' |
Usage |
The value of this user property contains the searchspec string to be applied to the Opportunity business component to retrieve the subopportunities during a change to the arrival date. This user property is used in C++ code for arrival date modifications functionality. |
