Siebel Loyalty Administration Guide > Getting Started with Siebel Loyalty > Performance Optimization for Siebel Loyalty >
About Assigning Server Keys to Members
Without configuring Siebel Loyalty, the Siebel Loyalty application automatically assigns keys to new members based on which key is the least loaded. The least loaded key is determined based on the number of members currently assigned to the key. This field that is maintained in the Server Key Map table by Siebel Loyalty and is not editable. You can control the logic used to generate keys by changing the user properties listed in Table 8.
Table 8. User Properties that Control Key Generation
LOY Member |
Auto Generate Key Flag |
Y or N to indicate if the key must be automatically generated. If not defined, then defaults to Y. |
LOY Server Key Map |
Auto Generate Key SearchSpec Search |
Search specification for keys to consider for assignment. Customer can specify a search specification such as [Number of Members] < 100000 to only use keys that are not yet fully loaded. |
Auto Generate Key SortSpec |
Sort specification to determine the least loaded key. The first key in the sort sequence is assigned to the next member. Without configuring Siebel Loyalty, it sorts in ascending order based on the Number of Members field. |
