Siebel Loyalty Administration Guide > Getting Started with Siebel Loyalty > Performance Optimization for Siebel Loyalty > Setting Up Server Keys for Siebel LoyaltyServer keys are used for batch components, not for real-time components. For more information about batch and real-time components, see Setting Up Server Components for Siebel Loyalty. Server keys are used for two reasons:
Siebel Loyalty automatically assigns the least-loaded key to new members. Using Server Keys for Load BalancingThe number of different keys you define depends on:
It is recommended that you assign ten keys to each server - process number combination to allow the administrator to do load balancing by shifting keys from one process to another. For example, imagine you determine that you need five server processes to process transactions. You have two servers available that can each run three processes, but one of them is already running another process. It is possible to create only five keys and assign them to the five available server processes, as shown in Table 7. However, if you create only five keys, then the administrator cannot manually switch keys from one process to another if one process is overloaded. Therefore, it is recommended that you define fifty keys. Initially, you assign ten of these keys to each process. If one of the processes is overloaded, then the administrator can reassign one or more keys from that process to other processes. Setting Up the Server KeysThe following procedure describes how to set up server keys.
Balancing Server LoadsThe following procedure describes how to balance the load on servers. |
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
