Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > Formulas in Siebel Loyalty >
Building Formulas
This topic includes instructions about building a formula.
To build a formula
  1. Navigate to the Loyalty Promotions Administration screen, then the Formula view.
  2. Click New.
  3. Complete the necessary fields. Some fields are described in the following table.
    Field
    Description
    Name
    Name of the formula
    Program Name
    Program name with which to associate the formula
    Description
    Brief description of the formula
  4. Click the Name of the formula created in Step 3.
  5. In the Promotion Formula Builder, define the formula operators and attributes:
    1. Click New.
    2. Complete the necessary fields. Some fields are described in the following table.
      Field
      Description
      Sequence
      Sequence number of the row
      Operator
      Mathematical operator
      Object
      Select from Literal, Member, Member Tier, Promotion and Transaction
      Attribute
      Attribute name
      Value
      Numeric value for Literal-type objects
    3. Repeat Step a and Step b for each operator or attribute in the formula.
  6. Ensure that the formula is a valid mathematical equation:
    1. If the Validate button is grayed out and the Validation Status bar is green, then skip to Step 7.
    2. Click Validate.
      A information message is displayed indicating the likely cause of the invalid formula.
    3. Correct the issues specified in the information message.
    4. Repeat Step b and Step c until the Validate button is grayed out and the Status bar is green.
  7. Click Menu, and select Save Record.
Siebel Loyalty Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
