Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > Formulas in Siebel Loyalty >
Associating a Formula with a Promotion
This topic includes instructions about associating a formula with a promotion.
To associate a formula at the promotion level
  1. Navigate to the Loyalty Promotions Administration screen, then the Promotions view.
  2. Select a Promotion.
    NOTE:  The Promotion that you select must have the same Program as the formula you intend to use.
  3. Click the Rules tab.
  4. Click New.
  5. Complete the necessary fields. Some fields are described in the following table.
    Field
    Description
    Sequence
    Sequence number of the row
    Name
    Name of the rule
    Apply To
    Choose to apply to Transactions or Attributes
    Description
    Description of the rule
    NOTE:  To use a formula in the rule, you must select Transactions for the Apply To field.
    For detailed instructions about creating rules and criteria, refer to Creating Rules for Loyalty Promotions and Creating Criteria for Loyalty Promotion Rules.
  6. Click the name of the rule that you defined in Step 5.
  7. Select Formula from the Object menu.
  8. Specify the name of the formula in the Attribute field.
  9. Navigate to the Loyalty Promotions Administration screen, then the Promotions view.
    Notice that the promotion objects have a new Object Type called Formula and that the attributes field displays the formula created. The formulas can now be used in criteria for comparisons and in actions for assuaging values or updating attributes with formula value.
Siebel Loyalty Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
