Siebel Order Management Infrastructure Guide > PSP Engine > Row Set Transformation Toolkit Methods > Merge MethodThe Merge method combines two or more row sets into a single row set. ArgumentsExampleFigure 27 shows an example of arguments for a PSP procedure step named Merge Ineligible, which uses the Merge method.
| Siebel Order Management Infrastructure Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
