Context |
Optional. Property set of variables shared across all rows. |
Output Row Set |
The property set used for output. |
Business Object |
The business object to query. |
Business Component |
The business component to query. |
Search Specification |
A search expression comprised of business component fields, literals, and variable values from {Context}. For example: [Account Id] = {Context.Account Id}
In Memory Search Specification |
Optional. Additional terms that are ANDed with the Search Specification. The In Memory Search Specification is executed in memory. This can be used only if Cache Enabled is Y. |
Cache Search Specification |
Optional. Additional terms that define the key values for the Level 1 cache; for example: [Price List Id] = {Row.Price List Id})
For more information, see About PSP Cache. |
Process Condition |
A Boolean condition that is evaluated to determine whether to process the query. |
Sort Specification |
Optional. A comma-separated list of business component fields used to sort the query result. |
Cache Enabled |
Optional. Specifies whether to cache query results. Y or N. the default is N. |
On First Match [1..20] |
Actions to perform on the first query result. |
On Match [1..20] |
Actions to perform on every query result. |
On Last Match [1..20] |
Actions to perform on the last query result. |
On No Match [1..20] |
Actions to perform if there are no query results. |
