Siebel Order Management Infrastructure Guide > PSP Engine > Row Set Transformation Toolkit Methods > Row Set Look-Up MethodThe Row Set Look-Up method looks up each input row in another row set using a specified search expression. For example, it could be used to check for compatibility. ArgumentsExampleFigure 29 shows an example of arguments for a PSP procedure step named Flag Incompatible Rows, which uses the Row Set Look-Up method.
| Siebel Order Management Infrastructure Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
